Tach, 2006 Ford Focus
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79862
Printed Date: April 26, 2026 at 12:34 AM
Topic: Tach, 2006 Ford Focus
Posted By: bobbernard
Subject: Tach, 2006 Ford Focus
Date Posted: July 02, 2006 at 6:06 PM
Hello!
I'm trying to install a Tach in my 2006 Focus. I'm looking for a Distributor, but there is none. My car instead uses a DIS (Distributor-Less Ignition System). The manual for the Tach says it supports these systems, with the Power/Ground/Light being in the "standard" locations, but with the green wire Tach signal being engine/model specific.
I think if I'm correct, my DIS engine has a coil per cylinder. My question? How would I go about fathoming finding the right connect for Tach signal without ripping through the engine clipping lots of wires and hoping I find the right one? Does anyone have any experience in this?
Thanks! Bob
Posted By: KarTuneMan
Date Posted: July 05, 2006 at 4:18 PM
Use the lt.grn/black at any coil. or the PCM in th pass. kick. connector 2 pin 35 same color
