93 Toyota Camry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7992
Printed Date: March 28, 2026 at 10:28 AM
Topic: 93 Toyota Camry
Posted By: terry1125
Subject: 93 Toyota Camry
Date Posted: January 11, 2003 at 12:15 PM
I have a Toyata camry that has a sony ex head unit in it is not geting any is turning on and of like there is no power getting to it anybody have any idea what it might be
Posted By: djfearny2
Date Posted: January 11, 2003 at 6:45 PM
check all fuses and if you want pull the radio out and see if the radio has a fuse on it personally which most after market sony radios do so . what your checking behind the radio is the yellow wire to have constant 12 volts even with the key out of the cylinder if this wire does not that check all fuses and most likely the one in the engine bay cause constant power is usually fused in the engine compartment. so basically check all fuses throughout the car as well as in the engine compartment.
Jon
Installer/Help Technician
---coral springs florida---
