2006 Mazda MX-5 Miata
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81243
Printed Date: March 20, 2026 at 5:05 AM
Topic: 2006 Mazda MX-5 Miata
Posted By: piomx5
Subject: 2006 Mazda MX-5 Miata
Date Posted: August 05, 2006 at 5:21 PM
2006 is a new design, so <2006 is no good.  Looking for all wiring for this car.  Installing Pioneer Navigation System.  Need VSS Specificly, but extra would be nice.
Posted By: piomx5
Date Posted: August 06, 2006 at 11:18 AM
I Found this, but the VSS wire is not where it says.  (I have heard there is a difference with systems with bose)  Can anyone confirm?  I am also looking for the Emergency Parking Positive lead:
SECURITY
Battery  WHITE/ RED  (+)  IGNITION SWITCH HARNESS
 Ignition 1  RED / BLACK  (+)  IGNITION SWITCH HARNESS
 Starter 1  WHITE/ BLACK  (+)  IGNITION SWITCH HARNESS
 All Door Trigger  WHITE/ RED  (-)  IN HARNESS IN DRIVERS KICKPANEL
 Trunk Trigger  RED / WHITE  (-)  AT LIGHT IN TRUNK
 Parking Lights  RED / BLACK  (+)  IN HARNESS IN DRIVERS KICKPANEL
REMOTE START
 Ignition 2  BLACK/ RED  (+)  IGNITION SWITCH HARNESS
 Accessory 1  GREEN/ RED  (+)  IGNITION SWITCH HARNESS
 Anti-Theft Type  UNIVERSAL IMMOBILIZER
 Anti-Theft Descript  THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
 Neutral Safety  VIOLET  (-)  AT MODULE ABOVE GAS PEDAL - PIN #18
 Tachometer  BROWN  (-)  AT MODULE ABOVE GAS PEDAL ON FIREWALL
 Speed Sense  BLACK/ WHITE  (AC)  IN HARNESS IN PASSENGER KICKPANEL
 Brake Lights  GREEN  (+)  AT SWITCH ABOVE BRAKE PEDAL
 Reverse Lights  RED / YELLOW  (+)  IN HARNESS IN DRIVERS KICKPANEL
DOOR LOCK
Power Unlock  RED / BLUE  (-)  AT DOORLOCK CONTROL MODULE NEAR STEERING COLUMN
 PowerLock  RED / BLUE  (-)  AT DOORLOCK CONTROL MODULE NEAR STEERING COLUMN
Headlights-Lo  BLACK/ BLUE  (+)  IGNITION SWITCH HARNESS
Wipers-Lo  BLACK/ WHITE  (+)  IGNITION SWITCH HARNESS
Posted By: piomx5
Date Posted: August 19, 2006 at 2:33 AM
Seriously, no one has any new info on this?  Looking for pinouts on Steering Wheel Controls too!
Posted By: josh1979
Date Posted: August 19, 2006 at 9:19 PM
12voltswht/grn (40A), yel/blk (15A) + ignition harness
IgnitionGREEN / WHITE + ignition harness
Parking Lights+BLACK/ green + driver kick, harness to rear
Parking Lights-BROWN / black - headlight switch
Headlightyellow/red - headlight switch
Trunk/Hatch Releasepurple - trunk release sw on dash or dr kick
Notes: If equipped, this wire is also found at the keyless control module under the driver side dash.
The trunk release motor wire is blue (+) at the relay or motor in the trunk.
Power Sliding DoorN/A
Speed Sensewhite (except BOSE) ac radio harness or cluster
WipersBLACK/ yel (L), BLACK/ blue (H) + windshield wiper switch
LF Window up/dnRED / white - RED / green A window switch on center console
RF Window up/dnGREEN/ red - WHITE/ red A window switch on center console
StarterWHITE/ blue + ignition harness
Second StarterN/A
Second IgnitionN/A
Third IgnitionN/A
Accessorypink/black + ignition harness
Second AccessoryWHITE/ red + ignition harness
KeysenseBROWN / red + ignition harness or cluster
Power LockBROWN / white - driver kick, door harness
Notes: Lock is negative trigger thru a 1000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlocksame as power lock wire
Lock Motorlt. green 5widriver kick, door harness
Unlock Motorgray 5widriver kick, door harness
Hazardsorange - hazard switch
Turn Signal(L)GREEN/ YELLOW + turn signal switch
Turn Signal(R)BLACK/ red + turn signal switch
Reverse LightRED / yellow + driver kick, harness to rear
Door Triggeruse dome supervision wire
Dome SupervisionBLACK/ blue - driver A pillar or cluster
Trunk/Hatch Pinorange to black - trunk pin switch or light in trunk
Hood Pingray - hood pin switch in latch or dr kick
Factory Alarm Armgray/red - driver kick, door harness
Notes: Meter this wire while turning the key in the driver door key cylinder.
Arm is negative trigger thru a 1000 ohm resistor. Disarm is a straight negative trigger. MUST use relays.
Factory Alarm Disarmsame as factory alarm arm wire
Disarm No Unlocksee factory alarm disarm
TachometerNOT blk/wht, blk, or wht/blue ac any ignition coil or fuel injector
Wait to startN/A
Brake WireBLACK / YELLOW + brake pedal switch or driver kick
Parking Brakegray - parking brake switch or cluster
Horn TriggerGREEN/ orange - horn switch
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
posted_image
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Door Lock Interface
Required:
Yes
Type:
Multiplex
Part #: 456LW
and if uor are trying to intesrface setring wheel controls tyr one of thes products the SWIX and the SWIPS
https://www.pac-audio.com/products/productsCatagory.asp?mmSearch=Steering%20Wheel%20Interface
bring back the rotary phone so i dont have to press 1 to proceed in english
