2004 Infinity G35 Sedan, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88150
Printed Date: April 20, 2026 at 4:35 PM
Topic: 2004 Infinity G35 Sedan, remote start
Posted By: Kevin Rodgers
Subject: 2004 Infinity G35 Sedan, remote start
Date Posted: January 01, 2007 at 9:40 AM
I'm looking to install a remote starter. Does anyone have the wiring diagram for 2004 Infinity G35 Sedan? Any other information what will help with this install?
Posted By: KarTuneMan
Date Posted: January 01, 2007 at 12:00 PM
Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS WHITE/ blue Ignition switch harness   +
 IGNITION BLACK/ red Ignition switch harness   +
 ACCESSORY WHITE/ black Ignition switch harness   +
 STARTER WHITE/ green Ignition switch harness   +
 STARTER 2 WHITE/ red Ignition switch harness   +
 KEY SENSE BLACK/ pink In 2-pin plug at steering column   +
 TACH SIGNAL SEE NOTES
 There are 3 wires at each of the 6 coils. A WHITE/ blue wire, a black wire, as well as a 3rd wire which can be used as a Tach reference.
 LOCK RED / white At switch in driver's door   -
 UNLOCK Blue/white At switch in driver's door   -
 This wire requires a double pulse to unlock all doors. A single pulse to this wire disarms the factory alarm.
 DOORPIN Yellow/red At light in driver's door   -
 This wire is not affected by the dome light delay and can be run into the car at the same time as the door lock wires. If you are not adding door lock control, separate door pins can be found at the BCM in the driver's kick panel, White (driver's door), Pink (pass. Door), Pink (rear doors).
 HOODPIN Lt.GREEN/ black At switch in front right engine compartment   -
 TRUNK PIN RED / white On small white plug at BCM in driver's kick   -
 TRUNK RELEASE Blue On Brown plug at BCM in driver's kick   -
 FACTORY ARM Arms with lock wire
 FACTORY DISARM Disarms with unlock wire
 BRAKESWITCH Pink/blue At switch above brake pedal   +
 PARKLIGHTS RED / blue In driver's kickpanel   +
 HAND BRAKE Violet/red At handbrake switch above driver's kick   -
 HORN GREEN/ black In 8-pin gray plug st steering column   -
 VSS WIRE WHITE/ green Behind radio, in harness   AC
