92 mustang 6 speaker wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92266
Printed Date: April 23, 2026 at 6:15 AM
Topic: 92 mustang 6 speaker wiring
Posted By: smolderingashes
Subject: 92 mustang 6 speaker wiring
Date Posted: March 29, 2007 at 7:00 PM
i found out the door speaker and rear speaker wire colors on here. i need help on the 2 speakers in the dash.
there are the two female plugs for the radio, then there are 2 male plugs (the 4 plugs look like they fit together). there is also 2 grey femles plugs (8 pronged i think), and a bunch of wires that someone had put wire connectors on.
Posted By: KarTuneMan
Date Posted: March 31, 2007 at 11:58 PM
| +12V DC Battery(Constant) | Lt.GREEN/ YELLOW | | 8 | 15 amp | Fuse panel | | Switched Accessory | Yellow/black | | 11 | 15 amp | Fuse panel | | Ground | Red | Could change to BLACK/ light green | | Illumination | Lt.blue/red | Also ORANGE / black |
AMPLIFIER OUTPUTS | |
| Wire Function | Color | Note | Fuse # | Size | Location | | 12V DC Battery | Yellow/black | | 11 | 15 amp | Fuse panel | | Left Front Mid + | ORANGE / lt.green | | | Left Front Mid - | Lt.blue/white | | | Right Front Mid + | WHITE/ lt.green | | | Right Front Mid - | Dk.GREEN/ orange | | | Left Rear Mid + | Pink/lt.green | | | Left Rear Mid - | Tan / YELLOW | Or pink/light blue | | Right Rear Mid + | Pink/lt.blue | | | Right Rear Mid - | BROWN / pink | Or Dark GREEN/ orange |
AT SPEAKERS | |
| Wire Function | Color | Note | | Left Front Tweeter + | ORANGE / lt.green | | | Left Front Tweeter - | Lt.blue/white | | | Right Front Tweeter + | WHITE/ lt.green | | | Right Front Tweeter - | Dk.GREEN/ orange | |
Available Notes | |
| Audio outputs (line level) from the radio going to the amplifier are as follows: radio pin-out section C281, pin 1 (light green) to amplifier pin 5 in section C282; radio pin 2 (BLACK/ white) to amplifier pin 2; radio pin 3 (light blue/black) to amplifier pin 6; radio pin 5 (WHITE/ red) to amplifier pin 4, and radio pin 7 (PURPLE / white) to amplifier pin 3. |
DOES THIS HELP? -------------
