bulldog deluxe 200b remote start 1990 accord
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92918
Printed Date: May 06, 2026 at 4:16 AM
Topic: bulldog deluxe 200b remote start 1990 accord
Posted By: aj_aj
Subject: bulldog deluxe 200b remote start 1990 accord
Date Posted: April 13, 2007 at 11:41 PM
hi there as I said i have bulldog deluxe 200b 2way remote starter I want to put it on 1990 honda accord but i don't know if my accord has any anti-theft system, any how alarm bypass module (IF114) came with it do I need to connect it too,it says bypass anti-theft system so i don't know if i should install it or not? if you are familiar with this system please let me know what to do thanks
Posted By: wlmpwlmp
Date Posted: April 14, 2007 at 6:46 AM
No factory anti-theft on this car. Heres the info you need to do the install tho.... | MODEL | YEAR(S) | | ACCORD | 1990 -1993 |
| KEY | T-HARNESS | IMMOBILIZER | | N/A | HON-2 | N/A |
| PART | COLOR | LOCATION | DIAGRAM | | 12 VOLT CONSTANT | WHITE (+) | IGNITION SWITCH HARNESS | | | STARTER | BLACK/ WHITE (+) | IGNITION SWITCH HARNESS | | | STARTER 2 | N/A | | | | IGNITION 1 | BLACK / YELLOW (+) | IGNITION SWITCH HARNESS | | | IGNITION 2 | N/A | | | | IGNITION 3 | N/A | | | | ACCESSORY /HEATER BLOWER 1 | YELLOW (+) | IGNITION SWITCH HARNESS | | | ACCESSORY /HEATER BLOWER 2 | N/A | | | | KEYSENSE | N/A | | | | PARKING LIGHTS ( - ) | N/A | | | | PARKING LIGHTS ( + ) | RED / BLACK (+) | @ FUSEBOX IN DRIVERS KICK PANEL | | | POWER LOCK | BLACK/ WHITE (TYPE B) | LOW IN DRIVERS KICK PANEL | | | POWER UNLOCK | BLACK/ RED (TYPE B) | LOW IN DRIVERS KICK PANEL | | | LOCK MOTOR WIRE | N/A | | | | DOOR TRIGGER | BLACK/ WHITE (-), | @ BROWN PLUG LEFT of STEERING COLUMN | | | DOMELIGHT SUPERVISION | USE DOOR TRIGGER, Requires Part #775 Relay | | | | TRUNK RELEASE | N/A | | | | SLIDING POWER DOOR | N/A | | | | HORN | LIGHT GREEN/ BLUE (-) | @ STEERING COLUMN HARNESS | | | TACH | BLUE | @ DISTRIBUTOR | | | WAIT TO START LIGHT | N/A | | | | BRAKE | GREEN / WHITE (+) | @ SWITCH ABOVE BRAKE PEDAL | | | FACTORY ALARM DISARM | N/A | | | | ANTI-THEFT | N/A | | |
------------- WesMan
Posted By: aj_aj
Date Posted: April 14, 2007 at 7:23 PM
thanks wesman but i have this sheet and I did connect all these wires still won't start I got the doors to lock and unlock tho ,but the starter won't work I looked for another sheet and it said there is a 2 IGNITION wire so I connected now I can hear there is a click when I push start button,but still won't work what else I can do to make it work, so as you said this car does not need any bypass?right thanks for looking
Posted By: wlmpwlmp
Date Posted: April 15, 2007 at 8:39 AM
did you hook up the tach wire? if so did you program that tach? check page 30 or your book, diagnostics section and do what it says there. report back how many flashes you get out of that led built into the starter brain. also did you install the safety shutdown toggle switch? if so try flipping it to the other position and try the R/S now!
Posted By: wlmpwlmp
Date Posted: April 15, 2007 at 8:45 AM
if your unit did not come with that toggle im talking about, then what did you connect the grey wire(safety shutdown) wire to? if it is hooked to ground then the starter wont start. the wire is supposed to be hooked to a hoodpin, so when the hood is up the brain will see ground and prevent accidental starting for you or say a mechanic who is under the hood. if you did just hook that grey wire to ground then un hook it from that ground and then try to start. ------------- WesMan
Posted By: aj_aj
Date Posted: April 15, 2007 at 7:06 PM
I did not connect the tach cuz it says if you want to program the feature IV-2 to (engine checking tach) otherwise do not connect this wire and tape the end.page 16 manual. and I did not connecet the safety switch it says optional but if i need that I will connect it. but there is one more wire I can not find the horn wire it says (light GREEN/ blue ) and I can not find that how ever I found light GREEN/ black is that the same wire(STEERING COLUMN HARNESS ) if not where can I find it. thanks wesman
Posted By: monkies
Date Posted: April 16, 2007 at 11:31 AM
Did you connect the small black wire on the H4 to ground?
What does it do when you press the start button twice? does the remote beep 3 times?
if h4/2 (thin black) is grounded and you still get the 3 beeps, then it might be a glitch in the unit. what you have to do it put it in tach mode then exit programming mode then put it back into engine checking voltage (tachless) and then it should start. I've seen alot of these units end up in a "limbo" mode that wasn't tach or tachless that usually takes care of the problem
Posted By: aj_aj
Date Posted: April 16, 2007 at 6:52 PM
yes I did connect that black wire from H4 to the ground. and I still can not find the horn's wire . the thing is I can not program it I did what the book says but still can not program it I dont know what to do with it, if you have an easy way to do it (programming)please let me know. thanks wesman for your help
Posted By: monkies
Date Posted: April 19, 2007 at 12:32 PM
Well make sure the remote control says the doors are unlocked (even if you don't have the door locks hooked up)that will keep you from entering program mode. You will need the horn to program if you can't find the horn wire use your test probe and look for a negative pulse on the horn wire on the unit instead of listening for the "chrip"
Posted By: aj_aj
Date Posted: April 21, 2007 at 4:13 PM
thanks man I will try that too and I hope its going to work this time .I will let you know thanks again
