2007 honda odyssey vss wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93165
Printed Date: May 12, 2026 at 5:55 PM
Topic: 2007 honda odyssey vss wire
Posted By: convoy2337
Subject: 2007 honda odyssey vss wire
Date Posted: April 20, 2007 at 12:31 PM
Just wanted to post a thread in regards to a 2007 honda odyssey vss wire. After hours of searching I finally got a schematic from Honda. The VSS wire is at the pcm but not in the location listed everywhere else i looked. The wire you need it in position B38 and is BLUE. Hope this helps someone.
Posted By: KarTuneMan
Date Posted: April 20, 2007 at 3:57 PM
VSS WIRE Orange At cruise module behind center console   AC
 Also found Blue/white at the PCM on the driver's side fender under the hood.
This info is NOT correct ??
