1991 nissan maxima w/ bose system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94170
Printed Date: April 19, 2026 at 4:21 AM
Topic: 1991 nissan maxima w/ bose system
Posted By: dk77
Subject: 1991 nissan maxima w/ bose system
Date Posted: May 23, 2007 at 12:08 AM
I bought a '91 Maxima and the harness is cut.  I have identified most of the wires using a DMM and the diagrams guide on this site (the diagram for the '89 Maxima is more accurate for my application than the '90/'91 posted).  I have three remaining wires left.  The unit powers up and retains memory, but there is no sound from the speakers.  Is there an amplifier?  Do I need to power it?  I can not seem to find any information as to a bypass harness, so I figured I could power the amplifier (if equipped).
Also, the speaker wires are a Belden type cable that has a wire shield around the conductors.  These wires tested for continuity to frame ground.  Should I do anything with the shields?  I have the shields taped back to their respective wire jackets at the moment.
Thanks in advance for any assistance!
Posted By: dk77
Date Posted: May 23, 2007 at 11:11 PM
OK...figured out the other three wires.  Amplifier, power antenna, and dimmer.  Connected the amplifier wire to the remote of the head unit.  Tunes started playing - sounded like garbage.  Rear speakers were distorted.  Front speakers worked fine, but then the right front stopped working after a couple of moments.
I'm taking this to the car audio forum...
