2007 honda civic, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94761
Printed Date: May 12, 2026 at 5:56 PM
Topic: 2007 honda civic, remote start
Posted By: frysbay25
Subject: 2007 honda civic, remote start
Date Posted: June 13, 2007 at 8:17 PM
Remote start for a 2007 Honda Civic Coupe
Posted By: rudydapimp
Date Posted: June 14, 2007 at 8:31 AM
This is what I could find on Code Alarms website. But as always - test all wires with a DMM
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
Ignition 2 BLACK/ RED (+) IGNITION SWITCH HARNESS
Accessory 1 WHITE/ RED (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Neutral Safety LIGHT GREEN (-) AT GEAR SELECTOR SWITCH
Tachometer BLUE (AC) AT PLUG NEAR VEHICLE BATTERY Speed Sense BLUE/WHITE (AC) AT MODULE TO LEFT OF STEERING COLUMN
Parking Lights RED / BLACK (+) IN HARNESS TO RIGHT OF STEERING COLUMN
Brake Lights WHITE/ BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Power Unlock WHITE/ GREEN (-) IN GRAY PLUG HIGH IN DRIVERS KICKPANEL
PowerLock WHITE/ BLUE (-) IN GRAY PLUG HIGH IN DRIVERS KICKPANEL
LF Latch GREEN (-) IN HARNESS IN DRIVERS KICKPANEL
RF Latch LIGHT GREEN/ RED (-) IN HARNESS IN DRIVERS KICKPANEL
Trunk Trigger BLUE/BLACK (-) IN HARNESS IN DRIVERS KICKPANEL
