2007 pontiac vibe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98997
Printed Date: April 18, 2026 at 2:00 AM
Topic: 2007 pontiac vibe
Posted By: accord313
Subject: 2007 pontiac vibe
Date Posted: November 14, 2007 at 11:40 AM
Does anybody have the wiring diagram for this vehicle? Thanks
Posted By: kola7126
Date Posted: November 14, 2007 at 5:37 PM
 MODEL YEAR(S)
 VIBE  2003 -2006
 KEY T-HARNESS IMMOBILIZER
  N/A   N/A   N/A
 PART  COLOR LOCATION
 12 VOLT CONSTANT  Connect to BATTERY ONLY
 STARTER RED (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
 IGNITION 2 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 BLUE/RED (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE N/A
 PARKING LIGHTS ( - ) GREEN / WHITE (-)  @ HEADLIGHT SWITCH
 PARKING LIGHTS ( + ) GREEN (+)  IN DRIVERS KICK PANEL
 POWER LOCK GREEN (TYPE B) See NOTE *1  IN DRIVERS KICK PANEL, 10-Pin Plug
 POWER UNLOCK BLUE / YELLOW (TYPE B) See NOTE *1  IN DRIVERS KICK PANEL, 10-Pin Plug
 DOOR TRIGGER RED / WHITE (-)  @ INTERIOR LIGHT SWITCH
 DOMELIGHT SUPERVISION RED / BLACK (-) or RED / YELLOW (-), Requires Part # 775 Relay  @ INTERIOR LIGHT SWITCH
 TRUNK RELEASE BLUE/WHITE (-), Requires Part # 775 Relay  @ HATCH RELEASE SWITCH
 SLIDING POWER DOOR N/A
 HORN GREEN/ YELLOW (-)  @ HORN SWITCH
 TACH BLACK  @ ECM, far RIGHT Plug, See NOTE *2
 WAIT TO START LIGHT N/A
 BRAKE GREEN / WHITE (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  DISARMS WITH UNLOCK
 ANTI-THEFT N/A
 EXTRA INFORMATION
 NOTE *1 these wires will only test when turning the key in the Drivers Door Key Cylinder. The BLUE / YELLOW (-) Unlock wire will require a Double Pulse to Unlock. If your unit does not have a Double Pulse unlock output, use the BLUE/BLACK (-) Unlock wire, in a BLUE 12-Pin Plug in the Passengers kick panel. This wire will only test with the key in the Passengers Key cylinder on the door. NOTE *2 the ECM (Electronic Control Module) is located BEHIND the GLOVEBOX
