Mobile video without headliner?
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10042
Printed Date: May 05, 2026 at 12:35 AM
Topic: Mobile video without headliner?
Posted By: csorb
Subject: Mobile video without headliner?
Date Posted: February 24, 2003 at 10:10 PM
Hi. A rent-a-car agency requested mobile video for some of their fleet. The only problem is, they want to be able to resell the vehicles without a loss, and do not want anything noticeable to be left on the headliner Is this humanly possible and without too much extra expense- or at all ? Thank you
Posted By: Chris Luongo
Date Posted: March 01, 2003 at 3:00 PM
On Toyota Siennas, I'm able to do an overhead video without cutting the headliner. I slide a piece of 3/8" plywood above the headliner through the sunroof opening, and re-use the domelight screws to fasten it in place. Then, I place the video on the ceiling, and put four screws through the headliner and into the wood.....if the video were taken out, the four holes are unsightly, but could probably be lived with.
If you could get longer screws with the same thread pitch as the Toyota domelight screws, you could probably fasten the wood onto the visible side of the headliner instead---this would eliminate the screw holes as well.
You might also check out the headrest monitors made by Vizualogic; we've used a few and they seem pretty good. You buy a complete headrest from them, with a 7" screen already built-in. Installation is quick, and the customer can save their factory headrests for resale time.
Posted By: securinu
Date Posted: March 02, 2003 at 8:19 AM
or you can use replacement headrest monitors....like myron and davis
Posted By: csorb
Date Posted: March 02, 2003 at 8:23 AM
Thanks for the info
