Need help installing XBOX/inverter/screen
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10076
Printed Date: May 05, 2026 at 5:27 AM
Topic: Need help installing XBOX/inverter/screen
Posted By: 02extreme
Subject: Need help installing XBOX/inverter/screen
Date Posted: February 25, 2003 at 6:03 PM
Greetings, I recently un-installed a set-up that was in my S-10 and now I want to re-install it...I have a power inverter and a relay with 4 wires coming off of it the colors are green, white red, and black, there was a gray one in there but we didn't need it so we pulled it out...I want to put this unit back into my vehicle but I am unsure on exactly how to wire this up...I have 2 wires that are coming off my ignition that are red and white together, that was in the cluster when I took the stuff out! Thanks in advance!!
Posted By: esmith69
Date Posted: February 25, 2003 at 10:05 PM
What year is your truck?  And how many wires did you pull out when you removed it before (and what colors/sizes were they)?
Date Posted: February 26, 2003 at 11:40 AM
2002 and, I pulled alot of other equipment before...I just need help figuring out how to wire the invertor with the ignition and the battery by using this relay!!!
Posted By: Ronald Mark
Date Posted: March 06, 2003 at 2:54 PM
Here goes: Your relay should be maked, if not orentate it to this picture and hook it upas follows. We have no way of telling what those wires go to on your relay. I have never seen a relay work with 3 wires.
Date Posted: March 06, 2003 at 2:57 PM
Sorry, pick didn't work. 85 to ground, 86 to ign., 30 to bat. + , and 87 to invertor.
Date Posted: March 30, 2003 at 6:01 PM
Its marked, but I dont know how to read it! There is 4 wires red. black, green and white, not quite sure where you got 3 from but...
Date Posted: March 30, 2003 at 6:02 PM
There is 4 wires coming off of it, red, green, black and white, Its marked but I dont know how to read that thing!
Date Posted: March 31, 2003 at 12:06 PM
hold your relay so it matches this pic.
posted_image
hook it up like I stated before.
