Alpine TME-M750 movement lockout bypass?
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10174
Printed Date: May 05, 2026 at 11:18 AM
Topic: Alpine TME-M750 movement lockout bypass?
Posted By: tel0p
Subject: Alpine TME-M750 movement lockout bypass?
Date Posted: February 27, 2003 at 6:23 PM
I have grounded the e-brake sense wire. Added +12V to the foot brake wire.
Still it says 'If you are driving pull over to use this function.' HELP!
Do I need the latcher (TR-7 from PAC)? If so what is the programming sequence?
Or am I missing something else? I realize there are wires for 'speed' and 'reverse' as well as the brakes.. It seems it just 'knows' when this damned Jeep (Cheroke) is moving!  Please somebody kick in with some info for me on this. THANK YOU!
Posted By: dashrat77
Date Posted: February 28, 2003 at 8:53 PM
Alpine commonly uses a sequence of: pressing foot brake (hold), press parking brake, release foot brake.
You can mimic this by using a momentary switch and a toggle switch.
Hook the momentary switch to 12v (other side to foot brake wire)
Hook the toggle switch to ground (other side to parking brake wire)
once hooked up turn system on and press & hold the momentary switch, flick the toggle switch on, release the momentary switch.
It should now let you in.
Posted By: tel0p
Date Posted: March 01, 2003 at 1:16 PM
Dashrat, you're a good man. I'll give it a shot. THANKS! posted_image
