aftermarket overhead mobile dvd
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111316
Printed Date: March 21, 2026 at 11:04 PM
Topic: aftermarket overhead mobile dvd
Posted By: ecalvemi
Subject: aftermarket overhead mobile dvd
Date Posted: February 04, 2009 at 2:52 PM
What is the easiest way to install an aftermarket  overhead Koss DVD player in a 2006 Honda CRV. It has 3 wires 1. White -to Dome light wiring 2.-Red (Hot). 3.-Black (ground). The dome light has 2 wires coming into it. Do I need to run a pos lead up from the fuseblock from an ignition switched circuit for the red wire, or is there a way to tap off the dome light circuitry? Have done some minor stereo install's but not a sophisticated installer. Thanks for your help!
Posted By: Mike M2
Date Posted: February 06, 2009 at 6:19 AM
White wire does to GREEN/ red on the light. The 12volts and ground you need to run under the dash...
Mike M2
Tech Manager
CS Dealer Services
Posted By: ecalvemi
Date Posted: February 06, 2009 at 10:49 PM
Thanks Mike I appreciate the feedback. I will try that as currently my hook up has caused the rear wiper and front and rear interior domelites to cease working. Rookie mistakes obviously!
Cheers Mike
