power rosen av7500 dvd
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113657
Printed Date: May 22, 2026 at 12:17 AM
Topic: power rosen av7500 dvd
Posted By: i3one21
Subject: power rosen av7500 dvd
Date Posted: May 07, 2009 at 8:49 AM
I have a 2008 Toyota Highlander
So I just got the Rosen AV7500 dual dvd headrest system yesterday and I wanted to make sure I connect everything properly.
There are 3 12v wires and 3 ground wires.  The main (red) 12V acc can connect to fuse #25 which is a 10A and says rear entertainment system.  (Is that the best way?)
I'm not quite sure where to connect the Gray 12V switch-Fmm and the Blue 12V (Aux source). Another question is do I even have to connect them if I don't use the FMM or an Aux source?
Can they all be connected in the fuse box and if so which fuse?
Posted By: Mike M2
Date Posted: May 13, 2009 at 6:35 AM
You don't need to connect the other wires at all, just the red set....
Mike M2
Tech Manager
CS Dealer Services
