oem tv antenna
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131593
Printed Date: March 22, 2026 at 4:52 AM
Topic: oem tv antenna
Posted By: orandaberg
Subject: oem tv antenna
Date Posted: June 12, 2012 at 4:11 AM
Hi I had the OEM TV option, being a 07 (european model) this was when analog signal was used, now digital is used, I am using the Kenwood 9260 BT with TV, instead of putting up another antenna in the front window ,can I use the OEM antennas to pick up the digital? Thanks
Date Posted: June 12, 2012 at 4:12 AM
Posted By: i am an idiot
Date Posted: June 12, 2012 at 3:43 PM
You can use whatever you like for an antenna. It does not matter what you use for an antenna, you will not be able to watch digital tv when the car is in motion.
Date Posted: June 12, 2012 at 10:46 PM
Thanks is that because of the law or because of you are actually in motion?
Date Posted: June 13, 2012 at 9:52 AM
You cannot pick up digital signals using the old style analog antenna. Digital signals are quite different from analog ones and the receiver would not be able to interpret them at all.
true or false?
Date Posted: June 13, 2012 at 10:59 AM
Nothing to do with the law. The antenna is not the issue, it is just the fact that there is so much more info needed on the digital end. Stationary, you can watch. Once in motion, it is too much trouble to decipher all the information.
Posted By: tommy...
Date Posted: June 13, 2012 at 11:12 AM
Accele makes a digital converter for auto use. Regular rabbit ear antennas will pick up the signal, the digital converter tweaks/converts the signal.
------------- M.E.C.P & First-Class
Date Posted: June 13, 2012 at 3:46 PM
At the end of the day I can use my Cadillac 07 anolog antenna and use my KTC 600E receiver to convert the signal correct`?
Posted By: Mike M2
Date Posted: June 20, 2012 at 5:39 PM
Are we sure analog is dead in Norway?
------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: June 20, 2012 at 11:22 PM
I never looked at his location.
Posted By: tommy...
Date Posted: June 22, 2012 at 7:18 AM
orandaberg wrote:
i
In his OP he said " Now Digital Is Used..." ------------- M.E.C.P & First-Class
Date Posted: June 25, 2012 at 8:46 PM
Yep EU uses Digital free to air now
Posted By: Mike M2
Date Posted: June 26, 2012 at 2:15 PM
Well hopefully the digital over there actually works, because here in the US it sucks. getting a signal while moving is tough here...
Tech Manager
CS Dealer Services
