dual/quad view
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131739
Printed Date: March 22, 2026 at 2:56 AM
Topic: dual/quad view
Posted By: scanboy
Subject: dual/quad view
Date Posted: July 02, 2012 at 4:53 PM
Hi, I'm wondering is there a 12v device that I could use to display two rca sources (camera) on the same monitor, in a split view. I want to be able to see the two cameras at the front corners of the car at the same time. My display do not support that type of input, so wondering if there's something I could add to do this. Thanks.
Posted By: oldspark
Date Posted: July 03, 2012 at 1:40 AM
Yes - a dual input monitor, or a dual input converter - though quad inputs are more common so leave 2 blank.
It requires more electronics than simple relays...
Posted By: scanboy
Date Posted: July 03, 2012 at 8:32 AM
Thanks for the reply. What do you call those boxes? I can't change my monitor, so I will need to add a box, but when I search for dual input converter, all kinds of stuff came up except for the box I'm looking for. Where can I buy such box?
Posted By: oldspark
Date Posted: July 04, 2012 at 1:36 AM
Are you sure you can't change your monitor? Ensure it is of good enough quality...
Here is one sample: Colorado Video Screen Splitter.
It's a mere $669 being in an ABS box (Aluminum is $829).
Posted By: scanboy
Date Posted: July 05, 2012 at 11:16 AM
I can't, for cost reason. The monitor is part of the navi which has a special plug to a box, the box does provide RCA input for rear cam and that's y I need this. Thanks
