Headrest Flush Look
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13507
Printed Date: May 10, 2026 at 4:59 PM
Topic: Headrest Flush Look
Posted By: Legrones
Subject: Headrest Flush Look
Date Posted: May 13, 2003 at 11:02 PM
 Hello could someone tell me how do I go by getting the nice smooth flush look in my headrest of my surburban I want the tv's so where it look like it is completely in the headrest and the shroud is not showing or is it some type of housing case i can order or buy from somewhere.
Dale / Cory
Posted By: brianh
Date Posted: May 18, 2003 at 8:09 PM
The way I do it is to not use the shroud at all. pop the screen out of the shroud and use it as your templete. Then to affix to the headrest just use some velcro on the foam. I have never had a problem doing it this way.   Brian
Posted By: Legrones
Date Posted: May 19, 2003 at 8:35 AM
 I also heard that people use mdf wood and place it inside the headrest and mount it in like that to
Dale / Cory
Posted By: Discman
Date Posted: May 25, 2003 at 8:31 PM
You could also try mounting the shroud flush in the hrest and then flap the material over the shroud and then push in the screen.
Good Luck
Posted By: Discman
Date Posted: May 25, 2003 at 8:35 PM
If you don't have the screens yet you should look at visualogic 7" screens that are pre-mounted in a replacement headrest for you. They look great and take 10 minutes to install. They are a little pricey but they save a lot of time and labor.
