Fm modulator help.
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15623
Printed Date: April 11, 2026 at 3:30 AM
Topic: Fm modulator help.
Posted By: ramsfan
Subject: Fm modulator help.
Date Posted: June 29, 2003 at 4:18 PM
Im installing an fm modulator on a stock radio on an f150.With the rca jacks on the modulator how do i go about  installing it to get sound.
Posted By: brianh
Date Posted: July 01, 2003 at 8:11 PM
All you need to do is to use a volt meter and find the 12 volt switched wire and the ground wire from the radio. Take the ground wire and attach it to the ground wire from the radio. Then do the same with the 12 volt switched wire. Unplug the antenna from the radio and plug it into the input on the modulator. Then take the other antenna coming off of the modulator and plug it into the radio. Then just tune the radio to the right channel and enjoy. Good luck with thwe install.
Brian
owner/installer
Sight & Sound Car Stereo
