video/vcr in 1998 dodge dakota
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27905
Printed Date: April 10, 2026 at 2:45 PM
Topic: video/vcr in 1998 dodge dakota
Posted By: sgopus
Subject: video/vcr in 1998 dodge dakota
Date Posted: March 07, 2004 at 5:04 PM
I have the entire system, to install a flip down 6" monitor, VCR and camera
The help I need is looking where to hook up to the power supply.
I have three wires on the system RED / blue/black, I understand the red is constant on, the blue is on only when the key is on, and the black is ground
The video I'm installing in the headliner, the camera is going on the dash
the VCR is being installed against the rear quater panel on the passenger side, the question is where do I run the power from??  I though of connecting to the dome light, but that goes off after a certain time, do I need to run clear to the fuse panel on the drivers side, and actally wire into the block??  thru the headliner or under the carpet
Posted By: JakeJ
Date Posted: March 08, 2004 at 12:32 AM
When I do a video system I go directly to the ignition wires at stering colum for constant and switched, (when I can) and ground to the kick panel. Make sure the power and grounds are all run to the same point.
Wyoming 12volt Enthusiast
Posted By: sgopus
Date Posted: March 08, 2004 at 7:39 AM
So since this is a truck, do you suggest running the wires via the headliner
or going under the carpet, since I have to take the headliner out anyway
to allow for mounting the flip down screen, it seems reasonable to run the wires via the headliner.
What do you think?
Posted By: JakeJ
Date Posted: March 08, 2004 at 8:53 AM
See which path is shortest and do it that way. Good Luck!!
