Indash dvd wont play!
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32411
Printed Date: April 07, 2026 at 6:10 AM
Topic: Indash dvd wont play!
Posted By: Loveforyou
Subject: Indash dvd wont play!
Date Posted: May 19, 2004 at 8:15 PM
I have indash dvd pioneer dvd7300&8000r brain. I have problem that the sreen just black out. I did hook the green wire to my parking brake. unlock the safety feature then just black out. my question do i need pioneer cd head unit to hook up this indash dvd? thank you for your time reading this.
Posted By: rabenoja
Date Posted: May 19, 2004 at 10:27 PM
Does it black out when you disengage your parking brake or is it black all the time?
Date Posted: May 20, 2004 at 4:52 AM
black screen all the time when i connect to parking brake nothing playing. when i disengage the parking brake the message come up''do drive while watching tv'' . am i doing something wrong please help. thank for you reply Rabenoja.
Posted By: outkastloz
Date Posted: May 29, 2004 at 1:30 AM
did you try just grounding out the green wire? try to do that maybe its not really sensing your parking brake signal?
------------- OUTKAST LOWRIDERS OF DETROIT MI. DETROITS FIRST LOWRIDER CLUB
Date Posted: May 29, 2004 at 10:03 PM
I'm not try to grounding the green wire I just hook up the to the parking brake switch. I mean i got question from the brain got green wire also this wire have to connect to parking brake? i try it but no luck i also try just ground the green wire samething black screen won't play? also i got no radio? i did hook the antenna up. thank for you reply
Posted By: Basscoholic23
Date Posted: May 29, 2004 at 10:40 PM
I had this problem with mine one time. I switched the RGB around to the other side of the master unit and worked.
Date Posted: May 31, 2004 at 9:02 PM
I have try it same problem. i hear is play dvd but the screen black? any one have this problem with this combo?
Posted By: Ravendarat
Date Posted: June 01, 2004 at 1:02 AM
I understand what you are trying to but take the green wire and conect it directly to a ground. If the picture comes on then you have a problem with the ebrake wire or you hooked it up to the wrong side of the switch. If it doesnt work then you may have a internal problem
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Date Posted: June 01, 2004 at 5:44 AM
thank you let try again I'll post back.
