Install 2 monitors side by side?
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33235
Printed Date: April 09, 2026 at 11:12 AM
Topic: Install 2 monitors side by side?
Posted By: cycho
Subject: Install 2 monitors side by side?
Date Posted: June 03, 2004 at 2:39 PM
I have a '04 Yukon XL Denali in which I would like to install a DVD system with two 10.2 inch widescreen Eiger Vision monitors.  I would like to minimize obstruction of the view from the rearview mirror.  Therefore, instead of mounting them in tandem, I was hoping to install them adjacent to each other, one just behind the driver seat, the other just behind the front passenger seat, allowing a relatively unobstructed rearview.
There appears to be enough clearance next to the rear airvents to accomplish this.  However, there is a slight slope to the roofliner at these off-center locations, probably about 10-15 degrees.  The monitors would both be tilted slightly if installed normally.  Is it possible to install the monitors so that they are visually level?  Will this cause one side of the monitor housing to extend out further than the other, or can this be avoided?
Thanks.
Posted By: mob.dynam.grad
Date Posted: June 03, 2004 at 9:49 PM
If i were u i would just build a wedge for one side of it to compensate for the angle and cover the wedge with the same material as the roof liner. That way it is less visable and with the wedge in you get a screen that is visually straight.
Posted By: auex
Date Posted: June 03, 2004 at 10:01 PM
Why the hell don't you just do headrest monitors?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: cs015271
Date Posted: June 04, 2004 at 9:00 AM
Because he wants 10.5" screens! Can you fit that in the headrest??
Posted By: tonyIrv
Date Posted: June 04, 2004 at 10:30 AM
If optional consoles are available for them, you could always cut the consoles to match the slope.
Posted By: auex
Date Posted: June 04, 2004 at 5:47 PM
Sure, just have to use alot of foam to make the headrest bigger. But the point of that was why would you want two 10.5 inch screens side by side? It is kinda like having 11 monitors in a extended cab pickup, its pointless, unfortunately I know 2 people who have this.
