Alpine CVA-1003, Can’t Get Video To Show
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33686
Printed Date: March 26, 2026 at 11:13 AM
Topic: Alpine CVA-1003, Can’t Get Video To Show
Posted By: javiermachuca
Subject: Alpine CVA-1003, Can’t Get Video To Show
Date Posted: June 11, 2004 at 12:47 PM
i have installed a alpine cva-1003 and i can't get a picture when i turn on my dvd player. the security feature is hooked up right because i could see the display and get into the setup menu and evrything else, but when i go to play a dvd all i get is a black screen and sound but no picture. the dvd player i have is not an alpine one but i also tried my ps2 and the same thing happens. my audio video cables are hooked up properly. can someone please help me on this issue? i've read the owners manuel but there's not much said on trouble shooting this problem. ------------- nvs65ss
Posted By: icacha
Date Posted: July 11, 2004 at 7:10 PM
have you connected the hand brake wire which is yellow/blue stripe to the hand brake wire or even to ground that might be the issue??? check it out...
Posted By: vekoma6382
Date Posted: July 14, 2004 at 4:57 PM
^^^If he is able to go into the setup then he has bypassed the "video interlock" which wouldn't be the issue. did you buy the unit used? ------------- If it doesn't fit.......make it fit.
Date Posted: July 14, 2004 at 6:30 PM
yes I did by this unit used.
Posted By: ronald Axson
Date Posted: August 17, 2004 at 12:01 PM
Javiermachuca Did you ever get your ps2 to work with the Alpine cva 1003. And if you did how did you get it to work? I ahve the same identical problem. I can get to the setup screen but no video from the ps2.
Posted By: raydawg357
Date Posted: August 18, 2004 at 2:23 PM
Are you sure you have the DVD connected to the input and not the output? Check in the setup menu and verify you have it set up correctly.
------------- Do it right the first time
Posted By: sleepybrown
Date Posted: August 22, 2004 at 10:15 PM
Im also having the same problem. Anyone have an answer?
Date Posted: August 23, 2004 at 6:45 AM
Ground the video
Date Posted: August 23, 2004 at 2:05 PM
So how does that work? Out of the three input wires(red,yellow,white) do I leave the rest connected and just ground the yellow? Or do I splice into the yellow and ground that wire and still leave the yellow video wire connected to the ps2? Or is there a different video wire I supposed to be dealing with?
Date Posted: August 23, 2004 at 5:53 PM
Worked like a charm, thanks!!!
Posted By: JRT2002
Date Posted: September 04, 2004 at 2:45 PM
I'm sort of just starting out. I bought an CVA-1003 and I'm trying to do the same things as everybody else--hooking up an PS2 and doing an video bypass. What I wanted to know is how did you'll do the bypass(or did you by one). And how did you'll ground the video?
------------- Jamael
