Need to test my new headrest monitors
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33816
Printed Date: March 26, 2026 at 3:33 AM
Topic: Need to test my new headrest monitors
Posted By: Jpritch
Subject: Need to test my new headrest monitors
Date Posted: June 13, 2004 at 5:43 PM
I am having trouble coming up with a solution to power them up to test that they did not arrive DOA.  Somebody on another forum said to hook it up to my battery, but with no further explanation.  I'm afraid of frying my new monitors using that method.  I am a novice at car electronics.
The only idea I have come up with thus far is to splice off a cigarette lighter adapter from a car electronic product and hook up the + and - from the monitor to the appropriate wires on the adapter and plug it into the outlet of my car.  Would this work?
I appreciate the input.
Posted By: Teamrf
Date Posted: June 14, 2004 at 12:18 AM
Why are you trying to "test" them. A lot of units just come with 12,switched,and ground wires. And a video input. I don't know why you would need to "test" them. But if you want to just give it power, and video.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: Jpritch
Date Posted: June 15, 2004 at 5:42 AM
I'm testing them to make sure they work as advertised as I only have a short window to return the product if defective.  I've heard of some monitors arriving DOA or with other problems.  I don't want this to happen to me.
My problem is getting the monitors power.  I don't know jack about cutting into my cars wiring system, which is why I asked about the cigarette lighter plug.  Not sure if this would work though.
I'm buying my A/V components as I can afford to buy them.  I'll have them installed professionally when I get everything I need.  But as I mentioned earlier, I need a way to verify that the items I buy work as advertised.  (I'm doing alot of Ebaying for these items, btw.)  So I hope you can understand my concern.
Posted By: aggie altima
Date Posted: June 15, 2004 at 10:45 AM
The Cigarette Lighter Adaptor should work. Just make sure you keep the fuse on the monitor's power wire connected to protect your monitor. If you don't want to cut a cigarette adaptor, you can connect the power wire of the monitor directly to the + of your car battery and the ground wire to your chassis (a good sanded spot). That's how me and the store workers I bought my screens from tested mine.
Jon
Don't like rockford subs? Then don't look at my car =)
Posted By: Jpritch
Date Posted: June 15, 2004 at 5:03 PM
Thanks for the info Aggie.
Is there anything in particular I should secure the wiring to the battery and ground locations with?  ie. elec tape....
Posted By: d-town7015
Date Posted: July 01, 2004 at 6:49 PM
Look if you want to test a monitor just use the same cables you use to charge a battery. Put the positive on postive and negative on negative and then connect the other side of the cables on your car battery. This will not harm the screen, I always use it to test my screens
