avic-n1 reverse signal polarity
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35612
Printed Date: May 16, 2026 at 9:50 AM
Topic: avic-n1 reverse signal polarity
Posted By: USM16
Subject: avic-n1 reverse signal polarity
Date Posted: July 14, 2004 at 11:07 PM
I am installing AVIC-N1 in 2004 Honda Odyssey
Pioneer Manual states that this wire looks for a "Change in voltage"
Obvious connection is to reverse lamps but, I can get the VSS signal and the reverse indicator lamp signal from the PCM plug directly behind the display unit for a clean install.
The reverse signal at the pcm grounds when reverse is selected and a relay is used to switch 12V to the actual reverse lamps.
Is the AVIC-N1 smart enough to determine the polarity when the car is in foreward motion or do I have to tap into the reverse relay output located way across the dash to provide +12V when in reverse?
US M16 (The Rifle)
Posted By: auex
Date Posted: July 14, 2004 at 11:20 PM
Yes, it is smart enough to detect a change in voltage or in state.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: USM16
Date Posted: July 14, 2004 at 11:39 PM
Thanks auex
How about the "light switch" connection at avic-n1, I have both a +12V lights on signal and a variable "dim" signal available at the vehicle radio plug.
Will the avic "dim" or is this supposed to be a solid 12V when the lights are on?
US M16 (The Rifle)
Posted By: kcmedic
Date Posted: July 17, 2004 at 12:51 PM
You need the solid 12v on/off. It doesn't use the dimmer.
