Panasonic DV 1500, CY-VM 5800U, no video
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38630
Printed Date: March 24, 2026 at 8:30 AM
Topic: Panasonic DV 1500, CY-VM 5800U, no video
Posted By: 92caddy
Subject: Panasonic DV 1500, CY-VM 5800U, no video
Date Posted: September 05, 2004 at 12:15 PM
I have a Panasonic DV 1500 DVD player and a CY-VM 5800U color LCD monitor. When I hook it up, all the monitor says is "WARNING". Any one know why this is happening? How do I get the DVD player to show on the screen? Do I need to ground the wire? Do I need a Brake Bypass for this? Does anyone have a wiring diagram or installation manual for this? Any help is greatly appreciated. :oops:
Posted By: Velocity Motors
Date Posted: September 05, 2004 at 12:27 PM
There is a parking brake wire that needs to see ground ( not sure what the color is for Panasonic ) but if this wire doesn't see a ground connection, no video .
------------- Jeff
Posted By: 92caddy
Date Posted: September 05, 2004 at 3:12 PM
It is a blue wire w/ a white strip.
Posted By: Ravendarat
Date Posted: September 05, 2004 at 6:42 PM
If that is listed as the parking brake wire make sure you get the right one and not amp remote turn one wire, cause if you do your gonna smoke that thing
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Posted By: motorfreak
Date Posted: September 20, 2004 at 10:06 AM
Im having the same problem, does the parking brake wire need to be connected or can you just bypass it and send to a ground wire?
