cva1004 brain on 1003?
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38647
Printed Date: March 24, 2026 at 11:44 AM
Topic: cva1004 brain on 1003?
Posted By: Boostedboogie
Subject: cva1004 brain on 1003?
Date Posted: September 05, 2004 at 6:28 PM
anyone know if this will work together? i need to buy an expansion pack and if i need to, i midas well get the one for the cva-1004 if it hooks up and works. reason is i don't mind having the extra graphics analyzers that the brain does for the cva-1004.
Posted By: raydawg357
Date Posted: September 08, 2004 at 10:07 AM
The KCE-104 for the CVA-1004 will not work with the 1003. There was an expansion module available for the 1003. Check on ebay. It's the KCE-103.
------------- Do it right the first time
Date Posted: September 09, 2004 at 2:11 AM
damn. any idea if the 1003 unit has the graphic equalizer visual effects that the 1004 expansion unit has?
Date Posted: September 09, 2004 at 7:24 AM
No it doesn't. I've own both, and as a matter of fact., the graphic EQ on the KCE-104 for the 1004 is rather cheesey. It has 5 different screens to choose from and the graphics are black and white with the peak points being blue. The 104 is essentially an expansion module. I wouldn't purchase it just for the graphic EQ. OH, by the way, it's not an EQ only a graphic display, you cant set any ranges.
Date Posted: September 10, 2004 at 4:19 AM
you've owned both? then can you answer this question for me reguarding the 1003... can i play/feed video into the unit w/o an expansion pack? or do i need the expansion pack to be able to feed video to the monitor?
Date Posted: September 10, 2004 at 9:30 AM
Yes, you can play and feed video into the unit. The expansion model is used to add extra monitors and additional inputs. The CVA-1003 has a video input.
