problems with the passenger screen
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39623
Printed Date: March 26, 2026 at 7:43 AM
Topic: problems with the passenger screen
Posted By: pecaron
Subject: problems with the passenger screen
Date Posted: September 23, 2004 at 1:07 PM
i installed theses FARENHEIT T-7000MHR 7.0" TFT/LCD Monitors in my trailblazers headrest and ran all the power connections from the ignition wire and set them up with seperate ground.  the first day both screens were working ok,  the next day i went for a ride w/my kids and they told me the passenger screen turned off but the driver screen is still on.  i pulled over took a look at the screens and the passenger screen was on but no picture i used the remote to turn it off and  on and the picture started flickering and then the picture faded away never turned off though.  i checked all my connections switched out the rca for the driver side and plugged into the passenger screen and still had problem on passenger side.  i dont know if this is a problem with connection from the ignition wire or if its the screen.  can anybody give some advise on troubleshooting this problem.  thanks!
i love this site:o)
Posted By: raydawg357
Date Posted: September 28, 2004 at 1:21 PM
Retrace all of your connections, make sure nothing is pinched or loose.  If the the left on works, plug the the right one into that  spot and see if it works.  You could have possibly came across a defective screen.
Do it right the first time
Posted By: pecaron
Date Posted: September 29, 2004 at 10:47 AM
hey thanks for the tips,  i switched the passenger screen to the drivers screens connections and still had problem.  i checked all connections everthing is ok.  im going to return the screen because i think your right i may have a defect in this screen.
thanks again!                                              posted_image
