noise / hum on monitor
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39958
Printed Date: March 25, 2026 at 12:40 PM
Topic: noise / hum on monitor
Posted By: jshell
Subject: noise / hum on monitor
Date Posted: September 28, 2004 at 9:18 PM
I just upgraded my lcd from a 13.3" to a 17" lcd tv. Always had a clear sharp picture on the 13.3" screen. I'm getting some noise, or a hum on the larger screen now. (it looks like diagonal lines that run on the screen). I did a search on the forum, and found some similar questions posted. One person had a solution to ground the video RCA cable......How do you do that? Another said to ground the monitor.....How? I'm getting all my power from an auxiulary battery(Optima, deep cycle) that came with the van(a 2001 VW Eurvan). Another post I saw suggested to get a ground loop isolator, or a video line filter. I'm a newbie--can someone give me a little more insight on how to do the above? What to try first? Thanks....
Posted By: raydawg357
Date Posted: September 29, 2004 at 11:11 AM
Most high end RCA's come with a ground wire that can be grounded on each end. A ground loop isolator will simply run between your unit and the rca's. You can also check the settings on your new screen. Simple adjustments will usually remove the diagonal lines.
------------- Do it right the first time
Posted By: fatgotti
Date Posted: October 13, 2004 at 10:39 PM
try to reground the monitors power ground and follow the video sigdal wire and keep it away from any hi amp current if all else fails try a video signal amplifier. post back if you can't understand my jibber jabber. I barley understand myself most ofthe time!!!!!!!!
------------- Fatgotti Yeah my name is John and I am FAT!! YEAH BABY
