AVIC-N1 in Land Rover Discovery
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42864
Printed Date: May 12, 2026 at 5:31 PM
Topic: AVIC-N1 in Land Rover Discovery
Posted By: Longshot421
Subject: AVIC-N1 in Land Rover Discovery
Date Posted: November 12, 2004 at 10:18 PM
Hi,
First, *n00b* alert.  I have done some very basic installs, but nothing too fancy.  I have just bought a used 1995 Land Rover Discovery.  Love the truck, hate the deck (Sony XR-5620 cassette).  So I have ordered a Pioneer AVIC-N1 and was planning to install it myself.  I have read the installation manual and I have the electrical manual for the truck, but I would love to hear any tips anyone might have.  The factory Land Rover deck is long gone, and I have dug into it, but I think the amps have also been removed.  The current deck is wired to 2 old Pioneer 6x9s in metal boxes on the floor behind the seat, so they're definitley going.  Then I will check out whether the factory speaker wiring is still hooked up to a harness anywhere.  Anyhow, like I said, I'd love to hear tips.
Thanks very much,
Mark
Posted By: drvnbysound
Date Posted: November 13, 2004 at 4:19 AM
It has been quite a while since I last installed in a Discovery, however knowing the factory radio has already been replaced most the work is probably already done, because there are no Metra or aftermarket branded harnesses which would have just let you plug and play a head unit. New wiring has to be run to the speaker locations, which was obviously already re-done since the Sony has been installed.
I did install an AVIC-N1 about 2 months ago in a 2003 H2. If you have any installation experience it shouldnt be to difficult. Just a matter of finding a place to and installing the brain, and wiring it all up, mostly just like any other HU besides the brake wire. For the AVIC to work upfront, w/o your parking brake to be on, connect the wire from the brake input on the AVIC to the constant 12V source.
If you have any other questions, feel free to ask. For quickest response, e-mail me at: drvnbysound@aol.com   or instant message me there if you have AOL or AIM
Date Posted: November 13, 2004 at 11:23 AM
Thanks Marvin, I think my main *shudder* points are making sure I get the right wire for the speed pickup (shouldn't be a problem) and the speaker wires.  You see, the current deck is just attached to speakers that are sitting behind the front seats on the floor with the speaker wire run through the centre console.  Not very pretty at all.  I'm not sure how much of the original wiring is in tact.  I do know that the factory subwoofer that is in the rear door has been removed, and I'm guessing the amplifier with it, though I'm not sure where it was located (haven't checked the book yet).   It's cold here right now (-15 °C), so I'm going make sure I've got a good plan before I go freezing myself in the driveway tearing the dash apart. posted_image I will have to make up my own harness (no nice plugs, just insulated male & female spade connectors or something) since as you said, nobody makes a nice plug I can just splice in.  Thanks for the contact info., I'll be in touch when I have a better idea what I've got myself into. posted_image
Cheers,
Mark
Posted By: DJEEPIN
Date Posted: November 13, 2004 at 11:40 PM
"your parking brake to be on, connect the wire from the brake input on the AVIC to the constant 12V source. "-it is wrong. Not a power source but ground. do not destroy unit
Posted By: DJEEPIN
Date Posted: November 14, 2004 at 12:06 AM
Thanks!  I re-read it after your post and figured it must be a typo.  Yes, the parking brake switch makes a connection to ground, so to keep it working all the time, I need to make the switch grounded all the time.  I had another thought:  The Discovery has dashboard controls for volume and next.  I wonder if I can substitute those inputs for the Pioneer wired remote and use them to control some of the AVIC-N1's functions.  Also, in the Installation manual, it has an Orange-White lead that is supposed to come from lights.  Is that so that the display dims when the headlights are on?  Must be.  The Land Rover has a lead for that function for the factory stereo, so I think that should work.  Thanks for the help.
Mark
