Kenwood KVT-911 DVD - Bypass?
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4401
Printed Date: May 05, 2026 at 9:27 PM
Topic: Kenwood KVT-911 DVD - Bypass?
Posted By: mixalot
Subject: Kenwood KVT-911 DVD - Bypass?
Date Posted: October 12, 2002 at 7:17 PM
Hi,
I just got a Kenwood KVT-911 DVD player and was wondering if the parking brake bypass is the same process as those listed before (switch between unit & parking brake) or if there's something else that needs to be done.
Thanks!
Posted By: Velocity Motors
Date Posted: October 12, 2002 at 8:37 PM
It's the same as the Panasonic and Alpine's.
Posted By: djfearny2
Date Posted: October 13, 2002 at 10:36 AM
question the kenwood 911 dvd is as the same as the alpine . in my experience the alpines are the most tedeous because there is a whole process to engage the video in these system involing the brake and a toggle switch . no other monitor etc is like that. what i thought is that all you have to do is ground the parking brake wire on the back of the 911 dvd velocity please calrify i dont have to much experience with kenwood . but i work at a shop that sells kenwood and would like to just know.
Jon
Installer/Help Technician
---coral springs florida---
Date Posted: October 13, 2002 at 12:32 PM
Should have clarified myself better. The Kenwood is the same as the Panasonic, Alpine, Pioneer's, etc in the fact that you have a safety wire that needs to see ground in order for the video to be operational. You are correct Jon, that Alpine has an extra step that the other's do not ( foot brake bypass & sequence steps ) that ensure that the video is not readily turned on by simply flicking a switch ( but still can be done with such a method ). All the Kenwood needs is a GROUND signal going to the GREEN wire and the video is operational while driving ( the same as the other companies where GROUND is required in order for the bypass to operate...except Alpine where you will also need the foot brake to see a momentary  12+ signal ).
