cva 1003 screen
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4671
Printed Date: May 06, 2026 at 6:45 AM
Topic: cva 1003 screen
Posted By: darkchild
Subject: cva 1003 screen
Date Posted: October 20, 2002 at 8:42 PM
has anybody worked on a cva 1003 i just tested it the only thing i had hooked up where my power and ground should the screen still come up.  also i just replaced the ribbon cable, could the part that is going into the monitor be the problem and stopping it from going up it beeps three times then it makes like a humming noise
Posted By: djfearny2
Date Posted: October 22, 2002 at 6:50 PM
if it is used there is probably something in the way i dont remember if that screen is fully motorized but if it is not comming out at all then there is def somethign wrong with it , you have the brain hooked up right the red yellow and black ground wire , yellow constant 12, red switched 12,
Jon
Installer/Help Technician
---coral springs florida---
