in-dash monitor wiring?
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55063
Printed Date: April 30, 2026 at 11:21 AM
Topic: in-dash monitor wiring?
Posted By: civic_sir
Subject: in-dash monitor wiring?
Date Posted: May 03, 2005 at 5:04 PM
hello everyone, welcome to stupid question time!
i just purchased a innovatek in-703L in-dash monitor for my 1999 civic sir coupe. too bad the instructions for wiring are notthat great. i was curious if anyone could help me out with the wiring on this matter, i am supplying ALL the info i can give everyone about the wires.
power supply 12v (has inline fuse)= RED
accumulator 12v (clock) yellow (which i assume is the same as the yellow for a cd player "memory")
black ground wire
mint green wire
the instructions say "ground with black & green wire"
so. . . does that mean to ground both the green & black in the same location? what about the ebrake line???
are there any suggestions on the best location for the power wire & the accumulator wire? thank you in advance
Posted By: Velocity Motors
Date Posted: May 03, 2005 at 11:57 PM
The green wire I will assume is your (-) input for the parking brake wire so that if this wire doesn't see a ground, the video will not work. To grab the constant wire ( YELLOW ) go to the BLUE/WHITE ( or WHITE/ BLUE, I can't remember but make sure that you check with a DMM or light tester ) wire on the wiring harness on the radio and the IGNITION wire you can grab the radio and the color is YELLOW/RED
Posted By: Captanham
Date Posted: May 04, 2005 at 11:03 PM
it's blue/white out of the radio
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
Posted By: auex
Date Posted: May 05, 2005 at 9:30 AM
I say constant is WHITE/ blue with 2 silver tracers.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
