KVT-915DVD Install question
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56930
Printed Date: April 30, 2026 at 8:20 PM
Topic: KVT-915DVD Install question
Posted By: rcmp5
Subject: KVT-915DVD Install question
Date Posted: June 02, 2005 at 10:00 PM
Ok,
I have a 915 that I am trying to wire into my truck. Upon reading over the book that comes with the unit I find myself with more questions then answers (kenwoods not very good about detailed info)...   On the wire connection page it shows two wires with the following descriptions.  Wire#1 (blue) power control wire - When using the optional power amplifier, connect to its power control terminal. Wire#2 (pink/black) external amplifier control wire - To "EXT.AMP.CONT." terminal of the amplifier having the external amp control function. My question is what is the difference between these two wires? I currently have the #2 wire connected to my amp's to turn them on/off with the head unit and wire#1 I have connected to my rear seat monitors power wire so they will also come on/off with the head. Would this be correct ???
Posted By: hawn13
Date Posted: June 02, 2005 at 10:16 PM
wire 1 remote turn on
wire 2 used for kenwood amps old excelons had power sliding doors you could open from kenwood deck with this wire.
If it works the way you have it now it should be fine. how many monitors do you have hooked to it 2 should be fine if you have more maybe put a relay on it
Posted By: rcmp5
Date Posted: June 02, 2005 at 10:50 PM
Thanks for the fast reply,
I am running two 6.5" monitors in the back, BTW I also have the TV antenna getting power from this line. Am I at risk of cooking the brain by running this from the remote wire?
Posted By: hawn13
Date Posted: June 03, 2005 at 8:15 AM
I would probably put a relay on it  better to be safe then sorry.
