AVH-5700 and PS2
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60010
Printed Date: April 25, 2026 at 9:30 AM
Topic: AVH-5700 and PS2
Posted By: jediraverz
Subject: AVH-5700 and PS2
Date Posted: July 24, 2005 at 10:52 PM
OK so I have a 2005 Subaru WRX wagon and I installed the AVH-5700 a Vector 400 watt power inverter and my PS2.
My question is when I turn on the inverter and have the Monitor set to Video everything is ok, when I plug in the PS2 even if its not on I get Audio and Video distortion , when I turn the PS2 on I get Very bad audio and white lines on the monitor. I have tried differnt cables for power from PS2 to inverter and Different cables from PS2 to monitor , also tried 2 other inverters. Could it be the Inverters that im using might be missing some kind of filter or something. I work in a Bay and when we do mobile video we usually use Monster Power inverters but we no longer carry them.
I also tried a Game Cube and it did the same thing. After all this I thought my car could have very poor grounds so I regrounded with 4Gauge wire and ground to a couple different points in the Engine bay. Any Advice will help. thanks
Posted By: Velocity Motors
Date Posted: July 25, 2005 at 9:25 AM
The only other thing that has not changed in your scenarios is the Pioneer unit. Have you tried installing other input devices like maybe a DVD player to see if the problem persists without the use of an inverter ? If the problem is still there with a DVD player, then I would suspect the Pioneer system.
