VSS wire 2005 nissan frontier
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60311
Printed Date: April 24, 2026 at 9:40 PM
Topic: VSS wire 2005 nissan frontier
Posted By: dirtydemo9
Subject: VSS wire 2005 nissan frontier
Date Posted: July 28, 2005 at 9:27 PM
VSS wire 2005 nissan frontier has anyone found it for navigation? The european model has nav as an option so there should be something that works?
Posted By: Velocity Motors
Date Posted: July 28, 2005 at 11:09 PM
THis has been a wire that has given alot of installer's problems because it is in some models but not in all. A good person to ask about this is Rob at Forbidden. His 12 volt member name is forbidden. THis is the information that I have on this:
LIGHT BLUE at the instrument cluster ( Pin 6 ) or at the radio harness.
Posted By: johnnyluv
Date Posted: August 02, 2005 at 5:16 PM
I'll check your diagrams when I get a chance at work, however the 05 Frontier uses a Controller Area Network like th 04 Titan read more at this post....https://www.the12volt.com/installbay/forum_posts.asp?tid=59453&PN=1
Anyway I'll see what info I can get for you...
---johnnyluv
Date Posted: August 02, 2005 at 5:59 PM
Thanks keep me posted, from what I have seen the C.A.N. has no way of comunicating with the AVN or any other navigation system for that matter. It seems to use a telemetry base comunication. Someone needs to make some kind of converter if that is possible.
Date Posted: August 02, 2005 at 6:04 PM
I would really like to know what the European models of Pathfinder and Frontier use for nav.
