Pioneer AVIC D1 bypass same as AVIC N1?
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60662
Printed Date: May 02, 2026 at 5:05 AM
Topic: Pioneer AVIC D1 bypass same as AVIC N1?
Posted By: Coloradope
Subject: Pioneer AVIC D1 bypass same as AVIC N1?
Date Posted: August 04, 2005 at 9:21 AM
Has anyone successfully bypassed the e-brake, VSS and Gyro with the D1 yet? I would assume it is very close to the N1 if not identical.
Also, are people having luck cutting the GPS antenna or is this not a good way to do this bypass?
Thanks for any help.
Posted By: 12V_REP
Date Posted: August 04, 2005 at 10:15 AM
No. Can't bypass the D1...period.
Date Posted: August 04, 2005 at 10:25 AM
Does this mean you cant do it right now, or you will never be able to do it?
What about an indash system like the Eclipse AVN5435...would this be able to be bypassed. The reason I bought this deck (AVIC D1) is because I have a child and I would like him to be able to watch DVD's on long trips. I have a Regular cab Chevy Colorado with Double DIN and would like an in dash screen, not a flipout, so you can see where my issue lies. Any suggestions?
Posted By: 12V_REP
Date Posted: August 04, 2005 at 2:33 PM
First off the AVIC-D1 is not a DVD player, so hopefully someone did not sell you this unit as a DVD player. Second, there has been no bypass that has worked yet that does not involve cutting stuff that is not meant to be cut, and I don't know if those have even worked. From what I have read on this site, the Eclipse is bypassable, although I do not know the method.
Posted By: granpa yum
Date Posted: August 04, 2005 at 2:41 PM
the best you can do is put a switch on the rear light sensor and 12v and hook the output for the rear screens into the input for the rear camera. this isnt the best solution but i hear it works
Posted By: godblessdremil
Date Posted: August 05, 2005 at 1:04 AM
It works, and is probally the simplest solution. Plus if i am not mistaken the other solutions ya can use gps while this ya can.
Posted By: dwhs
Date Posted: August 05, 2005 at 11:48 AM
I'm confused.
So step one:
What do you do with the e brake wire?
Step 2 :
You have to connect the brake light wire? And if so then where?
step 3:
Anygthing else that needs to be done?
Thanks,
Charles
Posted By: Dsteinmann
Date Posted: August 05, 2005 at 12:28 PM
Just Get a Kenwood DDX8017
Date Posted: August 08, 2005 at 11:03 PM
[I'm confused.
So step one:
What do you do with the e brake wire? install it like you normally would
Step 2 :
You have to connect the brake light wire? And if so then where? this is the hardest part. first, take an on-off switch(spst)(at radioshack for like 2 bucks).  then, connect one leg of the switch to a 12v power source. connect the other leg to the brake light wire. mount the switch and youre done.
step 3:
Anygthing else that needs to be done? hook your dvd player/ps2/whatever up as you normally would. take an rca cable and connect the rear screen video output to the rear view camera input.
the basic idea is that you want the system to think youre in reverse, so instead of connecting it to a brake light, you connect it to a switch so you can control that. then the rear screen output, which can always be watched, is fed into the rear view camera input, so it can be watched on the unit itself.
to my knowledge this does not void the warranty of the unit since you are not opening it or modifying it, but i could be wrong. and it is definatly illegal
Date Posted: August 08, 2005 at 11:07 PM
https://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F002%5F015%5F001&product%5fid=275%2D708
that would be a good switch, or any toggle switch really. just make sure its rated for automotive use(i had a switch burn up once back when i didnt know that much about electricity)
Posted By: gadfly
Date Posted: August 09, 2005 at 8:00 AM
Is there any other 1.5 din solutions like this? ( I know it says 2din, but it fits in most 1.5 without the trim)
I need to be able to bypass this so the kids can watch movies on the long trips. I do not want to mount an overhead or head rest monitor in my truck, so this is a perfect solution for passenger seat kid, and back seat kid alike.
Please don't lecture me on "makeing the streets safe" I don't watch tv while i drive, hell I refuse to talk on my cell phone while I drive (I personly think it should be illegal to talk on the phone while driving). But keeping kids entertained is a priceless saftey improvment, if you have kids, you know what I mean.
Posted By: AutoNavguy
Date Posted: August 09, 2005 at 9:33 PM
Please see this post for an easy way to bypass the AVIC-D1 lockouts, no massive relay banks required.
https://www.the12volt.com/installbay/forum_posts.asp?tid=61037&PN=1&tpn=1
Cheers
