5700dvd and explorer oem ohd mv
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61153
Printed Date: May 01, 2026 at 9:20 PM
Topic: 5700dvd and explorer oem ohd mv
Posted By: stavy customs1
Subject: 5700dvd and explorer oem ohd mv
Date Posted: August 11, 2005 at 3:12 PM
A customer came in and bought the pioneer 5700 he wanted it intagrated with his oem mv system in his 05 explorer. Now the oem mv system is power through the factory radio with a harness. I found the constant and switch in the harness but no ground. Now i wired those into the pioneer harness. The unit turns on and shuts off right away? What am i doing wrong? Is there something i need to goto ford about or will it not just work?
Best Buy Installer
Posted By: JTz62
Date Posted: August 18, 2005 at 2:44 PM
I've found that a lot of times the resistor on the ignition wire (the red one) will go bad and cause this problem. Test for power on both sides of the resistor to see if that's your problem.
