05 Magnum VSS
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61504
Printed Date: May 02, 2026 at 10:58 PM
Topic: 05 Magnum VSS
Posted By: Autosoundg
Subject: 05 Magnum VSS
Date Posted: August 17, 2005 at 7:43 AM
If anyone can help me out. Put a nav in a 05 Dodge Magnum and could not find VSS wire. Nav is now having problems and I put 2 magnets on and still not working. Anyone know wire color and location?
Help is greatly appreciated.
Thanks.............G.................
Posted By: extreme1
Date Posted: August 18, 2005 at 12:03 AM
wheel speed sensor, VSS is on the CAN-BUS
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: agr814fun2
Date Posted: September 21, 2005 at 11:16 AM
Vss is on the Can-Bus
recommended parts to generate a speed pulse:  VDO:  MA-3400
        Alpine:  NVE-K300
        Pioneer:  ND-PG12
        Kenwood:  KNA-PG100
This came from Eclipse tech support.  Good Luck
Posted By: jstruckman
Date Posted: September 28, 2005 at 3:12 PM
You can also use the CANPULSE2 from SoundGate. You tie into the CAN BUS wires and this will give you the analog speed sense signal you need. They are cheaper than the speed pulse generators and easier to install.
Jazzy
Posted By: extreme1
Date Posted: September 28, 2005 at 3:45 PM
Jazzy
Cheaper?? My cost on that piece is $300 CAD
Shaughn Murley
Visions Electronics
Red Deer, Alberta
