avic-n2/xdv-p9 disc changer
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61893
Printed Date: May 04, 2026 at 3:14 PM
Topic: avic-n2/xdv-p9 disc changer
Posted By: larrycad
Subject: avic-n2/xdv-p9 disc changer
Date Posted: August 23, 2005 at 12:43 PM
I am just a newbie, so don't be too hard on me.  I have a AVIC-N2, and a XDV-P9 disc changer I am attempting to install.  Can the disc changer feed directly into the AVIC, or do I need yet another "box", such as the GEX-P6400TV?  I want to be able to listen to CD's while navigating.  I really don't care about the video capabilities of the XDV.  Can I hook the XDV directly into the AVIC?  And what is the sequence.  I should also mention that I have a Pioneer XM tuner module hooked to the AVIC, and it is working via the IP-bus cable.  Any help would be appreciated.
Posted By: 12V_REP
Date Posted: August 24, 2005 at 8:53 AM
First off let me say welcome to the forums. Hoefully you will find this place as entertaining as the rest of us.
Okay, on to you topic. If I remember correctly you can basically plug and play. The XDVP9 is the older version of the XDVP90, but I think the difference is the 9 came with the IR sensor and remote where the 90 does not. I believe you will need the A/V cable that goes between the AVIC brain and the DVD changer, which you should already have. As for the XM Tuner and the P bus. All Pioneer XM Tuners have what is called a pass-thru, meaning an in and an out. So if you add any other sources, i.e. Sirius Tuner, Ipod Interface, yada yada, you will run the P bus out of the other source into the input of the Pioneer XM Tuner. Hopefully this helps more than it confuses. If you still are having troubles let me know and I will see if I can help.
