2005 Ford Van Speed Sens Wire
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64646
Printed Date: May 01, 2026 at 8:16 AM
Topic: 2005 Ford Van Speed Sens Wire
Posted By: sclausd56
Subject: 2005 Ford Van Speed Sens Wire
Date Posted: October 19, 2005 at 8:16 AM
Hi, guys. I know someone out there has to know where to find this thing. Thanks in advance for your help.
Jerry
Posted By: Velocity Motors
Date Posted: October 19, 2005 at 8:43 AM
It's located at the PCM under the hood, next to the brake master cylinder. On diesel vehicles the vss wire is in pin 22, in the top plug. The wire color is GRAY/BLACK pin #1 top plug for gas engines.
Date Posted: October 19, 2005 at 11:48 AM
Hey, Jeff. Thanks alot for the info. Is it ok to unplug the top connector without disconnecting the battery? Or should I disconnect positive cable first? Also, I'm not sure how the pin arrangement works, Is there only one black and gray wire? If these are real stupid questions, I apologize. Thanks again.
Jerry
Date Posted: October 24, 2005 at 7:39 AM
Thank you, everyone for your help. You guys probably don't do many Ford vans, but I found the gray/black speed sens wire in the middle plug at the PCM, not the top plug. It must be the proper wire cuz it's getting the signal. Thanks again.
Jerry
