VSS wire in 1996 GMC Jimmy
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66906
Printed Date: May 16, 2026 at 2:57 PM
Topic: VSS wire in 1996 GMC Jimmy
Posted By: turbovr6
Subject: VSS wire in 1996 GMC Jimmy
Date Posted: November 23, 2005 at 6:22 PM
Can someone tell me where this wire is, and if it is analog or digital?  I found a diagram on this site that points to the abs module. My nav. install manual says DO NOT tap into the abs harness.
Jay
Posted By: extreme1
Date Posted: November 23, 2005 at 8:06 PM
GREEN / WHITE @ the ECM under the hood, or at the instrument cluster. Or at the radio if the factory had volume sensitive volume
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: turbovr6
Date Posted: November 23, 2005 at 8:50 PM
Thanks for that quick reply.   I was reading that there should be a VSS wire in my over head console. Would you know which wire that is? It would be much easier for me to route a wire up there.
Posted By: extreme1
Date Posted: November 23, 2005 at 9:58 PM
same color, I don't know why there'd be one up there though.
Instrument cluster seems the best bet.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: turbovr6
Date Posted: November 24, 2005 at 11:09 AM
Thanks again. over on the s10 forums the claim is that the temp and or compass use the vss as an update signal
Posted By: rlith
Date Posted: November 27, 2005 at 1:52 PM
For the temp...
Yo
