nav in 2006 H3
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67212
Printed Date: May 16, 2026 at 5:48 PM
Topic: nav in 2006 H3
Posted By: carstereoman
Subject: nav in 2006 H3
Date Posted: November 28, 2005 at 4:29 PM
Does anyone know about the new H3? I am trying to install a Pioneer avic-d1 or avic-n2. Metra has said they have a dash kit and have told me how to modify the GMOS-04 to work in the H3(make a jumper between the to purple wires in the data cable). Does the new H3 have a speed sense wire? Anyone run into any other problems with these? Any help would be awesome!
Posted By: sparkie
Date Posted: November 28, 2005 at 5:37 PM
The VSS is dark GREEN / WHITE at pin 21 of the engine computer in the first connector plug. I haven't seen the new dash kit yet, but I heard there is now one available.
sparky
Posted By: oddball
Date Posted: December 03, 2005 at 11:20 PM
Hello carstereoman,
AVIC-D1&N2 are Double-DIN? Scosche GM1595B might be fitted,but I did not try this kit.call Scosche for details. As VSS of H3, no need to wire from PCM.here is solution. your radio has "Auto Volume" at the right side of bottom? If so, just behind radio, there are 2 connectors available, 12way connector pinE is it. If no "auto volume" with radio, just behind passenger's kick panel.you can see flat 22 way connector with lock-tab. A8 is it. As GMOS-04,I never use this interface yet,coz our country has "NO STAR",so I always kill "ON STAR", here is wiring solution of class 2 data serial. First check the connector of Metra. "1A" is pink, this wire should run to vehicle's class 2 data line(purple). your vehicle's RPO is UE1, this is collect. if U2K, there are 3 purple wires from both radio connectors.A1,A2(24way) and G(12way). these 3 wires should go to Metra's pink wire. so soldering or electro-tapping is required. other case is:purple wire is located at A2, just relocate to A1. RPO code is located inside glove box.   GOOD LUCK!
