DVD on switched 12v
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69385
Printed Date: May 13, 2026 at 4:11 AM
Topic: DVD on switched 12v
Posted By: gspot35
Subject: DVD on switched 12v
Date Posted: December 28, 2005 at 12:30 PM
I have a DVD player in my truck that I have hooked up to switched 12V.  It only comes with a single lead, and no constant 12v for power.  It is very annoying to have to start your place over everytime you start the truck.  Has anyone here used a 1F cap to power the DVD player while not having the 12V switched to on.  This seems like it would work, and won't run the risk of killing your battery over night while running a DVD player.  Anyone have any thoughts?
Also, can anyone recommend an inexpensive AV switcher?
Posted By: guatemalanboy
Date Posted: January 04, 2006 at 6:25 PM
before u turn the truck off turn the dvd off and next time u turn dvd player back on movie will start where u left off should work, that's how most dvd players work that have a 12 volt acc and ground wires only let me know if it works
100%Guatemalan
Posted By: auex
Date Posted: January 04, 2006 at 6:29 PM
A cap won't work. It would supply power for a minute max.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: laztkall4alkoho
Date Posted: February 04, 2006 at 10:27 PM
i have a dvd player with a 12v connection to the cigarette/12 v power...can i cut the wires and try to run a 12v positive and one negative?? if so, how can i do this? can i make a switch? it would be better if it had 3 wires positive/negative/acc but it doesnt. i wana just run it with the positive and negative wiring if possible... can i do this??? pls help
LEO
Posted By: paulmarq
Date Posted: February 07, 2006 at 3:52 PM
i need help on how to install a camera and recorder type device to a 12v system.  Any suggestions or diagrams to share.
pmarquez
