avic-d1 map screen lag, no vss
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72340
Printed Date: May 08, 2026 at 11:46 AM
Topic: avic-d1 map screen lag, no vss
Posted By: trm420tm
Subject: avic-d1 map screen lag, no vss
Date Posted: February 07, 2006 at 2:10 AM
My avic-d1 is connected to a 2006 scion tc without the vss wire to facilitate video playback. This may or may not have anything to do with the problem i'm having- please let me know: Do you ever notice your d1 lagging way behind the actual location while driving in map mode? I'll be driving down the road, and all the sudden the car icon and map freeze for 15-60 seconds before jumping to the current location. Its made me miss quite a few turns as it happens mostly in unfamiliar areas (when i use the nav more) and im beginning to wonder whether i have a defective unit, or if its just because the vss isnt connected- any input would be greatly appreaciated. thanks for the quick reply!
Tristan Muehleib
Sakes and Leasing
Radley Acura,
Bailey's Crossroads, VA
703.200.1633 (cell)
703.824.5700 (office)
radleysales@gmail.com
Posted By: sush1a
Date Posted: February 07, 2006 at 2:54 AM
I would say that you've answered your own question.
Posted By: 12V_REP
Date Posted: February 07, 2006 at 8:13 AM
Pioneer utilizes 3 methods of tracking, GPS, Gyro and speed. Obviously it can work without all three, but works much better and the way Pioneer intended it to with all three. I am willing to bet if you hook up your VSS you will notice an immediate resolve to your problem.
Posted By: ryanerb
Date Posted: February 07, 2006 at 9:47 AM
hook up your vss wire and use the d1 hack that has been posted a zillion times. your vss wire will work and you will get video playback.
Posted By: ohlarikd
Date Posted: February 07, 2006 at 9:50 AM
My installer forgot to install my VSS wire initially, and yes, the location was off.  The D1 only gets GPS positions every few seconds, not continuously.  Between updates, it uses the various sensors to estimate location as you move.  When it gets a GPS update, it notes the difference in its calculation and the GPS position, and updates a running table of correction factors.  Over time, accuracy increases significantly.
When my installer finally connected the wire, I noticed that the tracking got much better.  You will also see that the algorithm switches from Simple to 3D Calibration.
You NEED the VSS wire.  You also need the Reverse Wire hooked up so it can tell if you are going backward.  Again, my installer forgot that wire too, so when I would back out of the driveway, the map showed me crashing in to my house.  And when GPS put me back on the road, the correction factors got all messed up.  When properly connected, the D1 is pretty accurate (of course, GPS is only accurate with a few meters, unless it ever implemented differential GPS).
Derek
