Avic- N2 Having to Ground Rca’s?
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72750
Printed Date: May 09, 2026 at 1:54 AM
Topic: Avic- N2 Having to Ground Rca’s?
Posted By: deenasty
Subject: Avic- N2 Having to Ground Rca’s?
Date Posted: February 13, 2006 at 1:16 PM
I just installed a Pioneer Avic N-2 Into my TA.  I am also running a JL 500/1 amp for my 2 JL w3 12's; and a jl 300/4 for my mid's and high's and an external crossover.  When I connected everything I was having really bad feedback, even with the radio off.  I was told the remote always stays on on a navigation unit.  The only way I got rid of it was if I grounded the rca's!  I ran a wire from the ground on the radio to the outer edge of the rca's and the noise is gone. What can cause this?
Posted By: Brianas
Date Posted: February 13, 2006 at 4:36 PM
do you have all your equipment properly grounded?
try a chassis ground for the N2
Posted By: free_refil
Date Posted: February 13, 2006 at 4:40 PM
I would also try grounding all of your equipment to the same grounding point.
Pioneer AVIC-F700BT
Polk Audio MM6
Alpine MRD-M605
Alpine MRV-F450
Alpine SWR-1242D
RF 1 Farad Cap
Streetwires ZN Interconnects
KnuKoncepts Power Wire
Posted By: deenasty
Date Posted: February 14, 2006 at 10:33 PM
well im using a smart harness for the radio, and my amps are both grounded to the same point.  I grounded the rca's and a lot of noise went away but not 100%.  You suggest me chassis ground the deck?
Date Posted: February 18, 2006 at 4:54 PM
That's what I'd do, chassis ground it to same point as your amps and other equipment are grounded.
Pioneer AVIC-F700BT
Polk Audio MM6
Alpine MRD-M605
Alpine MRV-F450
Alpine SWR-1242D
RF 1 Farad Cap
Posted By: ohlarikd
Date Posted: February 19, 2006 at 7:57 PM
If its not feasible to ground everything to the same point, try a RCA Ground Loop Isolator. You can get them from Radio Shack, or elsewhere I assume. I used them in my old truck and all the noise went away 100%.
Derek
Posted By: deenasty
Date Posted: March 06, 2006 at 10:59 PM
well I got rid of the engine noise by grounding the rca's. I tried a chassis ground with all of the points, and no luck.  The only other noises I am hearing now is the radio "thinking" or "processing". Like small series of beeps, or when the cd spins.  What in the world is this?
Posted By: ohlarikd
Date Posted: March 07, 2006 at 10:10 PM
Try the isolator....
https://www.radioshack.com/product/index.jsp?productid=2062214&cp=&kw=ground+loop+isolator&parentPage=search
$17, worth a shot. I bought 3. But get one and disconnect the rear and sub to see if there is any difference.
Derek
Posted By: customnate
Date Posted: March 14, 2006 at 10:07 PM
OKAY!! First off guys a ground loop isolator isnt gonna do jack its like a capacitor a short term fix!
OKAY i have had this issue before!! anything ya can imagine to go wrong ive seen it lol!!
First off you have to recognize a few things!!
What RCAS are you running? second is signal and power running down the same side?
and on navigation the remote lead stays on like you are saying but it pulls so little current its not going to effec the system!!
If you ground chasis the radio, and did everyhting else correct, you have a short in the RCAS or the preouts on the deck are going bad, or shorting out inside the circuit board of the deck!!
any other questions get ahold of me at work man
727-726-3383
ask for NATE thats me =)
Sinceryly,
The Custom Nate
Posted By: Ballerinstaller
Date Posted: March 15, 2006 at 3:32 AM
I got the same thing. I was able to hear some beeps, bleeps, whirs, clicks, and some hiss. Most of the music sounded like it was coming out of a church, not much stereo dimension. If you have similar symptoms, I hate to break it to ya, but you probably blew open the ground fuse to your rca's. You can verify this by disconnecting all rca's to amps and other accessories. Then ohm out the shield to the chassis of the radio with the power disconnected. You shoud see less than 5 ohms. If not, and you read about 200kohm, you blew the fuse.
     This happened to mine and my fix is to open the radio up, locate the small board that the rca's plug into in the rear. Desolder the board in the two spots. Remove the board and turn it over. Locate the tiny black package that has white writing on it. It should say something like fz101 or something like that on the circuit board right next to it. Jumper over it with a piece of small wire and presto! No more crappy audio.
You may ask how this can happen. Usually it is caused by a bad ground on an amp. Mine was caused by some strange cross connection through my neon lights, which no one has yet to figure out how that happened as I was no where near the radio nor the rca's during the install. (possible weak part in radio??)
Pioneer Avic-N1
Clarion 300 watt 4 channel amp
PPI PC21400 1400 watt amp
2x JL 12 inch w7's
Polk EX series in factory locations
2000 Impala LS
Baller Installer - Pete D.
Posted By: ohlarikd
Date Posted: March 15, 2006 at 11:18 PM
If its that bad, then yes, the isolator won't help - most likely. Sounds evil, these internal fuses...
Derek
Posted By: gbear14275
Date Posted: March 22, 2006 at 1:59 PM
This all sounds very weird to me. From what I understand one of the most common sources of noise is a shared ground from the power suppply in the amp and the reference with the RCA's (I might not have my terminology right).  A ground loop isolator eliminates this by using a transformer with a 1:1 winding so only the AC signal gets through.  (again I'm not posisitve but I can PM someone who can probably do better).  I am especially bothered by taking components off the circut board and shorting the connections(replacing them maybe, but shorting them out??? no.).
Posted By: chaos420
Date Posted: March 28, 2006 at 5:21 PM
I m having the same problem and tried everything i could think of.  The only progress i got was by grounding the rca's but it did not get rid of the noise 100%.  I checked the resistance of the rca ground fuse and got nothing, infinite resistance.  is theat directly related and can i assume i found the problem?
Date Posted: March 29, 2006 at 2:22 AM
Yup.  If you don't have a replacement fuse and you have decent soldering abilities, just use a single strand of copper wire taken from some speaker wire and jumper across the fuse.  /////Before you use this though, check your work by verifying that you are on the right component./////  Do this by putting one lead of your ohm meter on the shield of any RCA jack on the rear of the unit and place the other lead on either side of the component you believe is the fuse.  One side should read real close to 0 ohms.   the other side of the suspect component should read 0 ohms from the metal chassis to the component.  Then you know you are right on the money on finding the open fuse. If you cannot get a low ohm reading on either side of the component, check other suspect components and burnt circuit traces instead.
Pioneer Avic-N1
2x JL 12 inch w7's
2000 Impala LS
