05 Tundra D-Cab, Need Advice
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73416
Printed Date: May 15, 2026 at 1:31 AM
Topic: 05 Tundra D-Cab, Need Advice
Posted By: unwired
Subject: 05 Tundra D-Cab, Need Advice
Date Posted: February 24, 2006 at 12:16 PM
Vehicle; 2005 Tundra Double Cab, non JBL sustem.
Shortly after purchasing it I had my Clarion VRX610 hu installed. I'm realizing now that I should have spent a few more dollars and purchased a double din nav or nav ready hu. Since that time I have had the center of the dash off a couple of times hooking up a 10 disc dvd player and making a few minor fit ajustments. My thoughts are that this job should not be too difficult.
After doing a lot of research I'm finding the aftermarket double din hu's with nav or nav ready demensions are approx. 7"w x 4"h +/- a couple of cm's.
My question is; Since the dash opening on my Tundra is 7 7/8" wide, what are the installers using to fill the void on each side of the hu? Is there a standard kit or is it custom cut abs?
Any installation tips would be greatly appreciated.
Posted By: Velocity Motors
Date Posted: February 24, 2006 at 12:41 PM
I usually use fiberglass and ABS plastic to fill the gap in and to flush mount the unit into the opening.
------------- Jeff
Posted By: unwired
Date Posted: February 24, 2006 at 1:03 PM
Are you cutting an entire faceplate out of abs or fiberglass or cutting pieces to cover the void on each side? Thanks for the response.
Date Posted: February 24, 2006 at 2:55 PM
I usually cut out the template for the entire area because this adds strength to the face of the factory peice. It also gives you mounting surface for the short strand fiberglass to adhere to.
------------- Jeff
Posted By: trdtim
Date Posted: February 25, 2006 at 11:54 AM
They are probably using the SCOSCHE plates that go on either side. That's what they used to fill the gap on my 4Runner. Model number TA1465B fitls 2000-UP toyota double ISO DIN trim brackets. Hope that helps.
Posted By: unwired
Date Posted: February 25, 2006 at 4:15 PM
Thanks for the information Velocity Motors and trdtim! Since I'm not an expert installer I'll check ot the Schosche kit. Maybe oine of the local shops hs one available. Beyond that I'll leave it to the pros for the install.
Posted By: trdtim
Date Posted: February 25, 2006 at 8:27 PM
These are what those gap fillers look like........
Posted By: unwired
Date Posted: February 27, 2006 at 11:14 AM
The picture you posted is very helpful trdtim. Thanks you.
