How to connect to Add-a-Circuit
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7792
Printed Date: May 01, 2026 at 7:10 AM
Topic: How to connect to Add-a-Circuit
Posted By: 4My2Boyz
Subject: How to connect to Add-a-Circuit
Date Posted: January 07, 2003 at 3:25 PM
Can anyone tell me how to connect a 12v dvd player to an Add-a-Circuit fuse. Or what ways are there to powering an in car dvd player without using a cigaretter lighter?
Posted By: F4Pilot
Date Posted: January 07, 2003 at 3:47 PM
Solder in a 10 or 12 guage power wire from your ignition wire, run it to where your components will be mounted and then you can series in a few other things like a monitor, EQ, or other power source.  Make sure to utilize fuse holders with the proper respective ratings.
02 Odyssey / 99 F4
Posted By: auex
Date Posted: January 08, 2003 at 7:16 PM
You can just hard wire the dvd player.  Easiest way would be to cut the cigarette lighter adapter ,being careful to seperate the wires if they are not already marked, and test the plug in side to find out which wire is positive and which wire is negative.  Take the negative and ground it and then wire the positive to a source of power, depending when you would like it to come on.  You could connect it to an acc wire or wire it to a switch that has a fused constant 12V.  As for going through the fuse box, it would be a little too much trouble in newer vehicles.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
