VSS Wire Necessary?
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78893
Printed Date: April 19, 2026 at 3:42 PM
Topic: VSS Wire Necessary?
Posted By: bigrims111
Subject: VSS Wire Necessary?
Date Posted: June 08, 2006 at 3:01 PM
I can not find information on the vss wire for 18-wheelers for the life of me.  If anybody could help me with this information that would be great.  If not I dont think ill will be able to hook up navigation to these vehicles without the vss wire hooked up.  Any input would be great thanks guys.
If it aint broke no need for solder
Posted By: djfearny2
Date Posted: June 08, 2006 at 6:50 PM
vss is not required but the unit will have be sluggish on knowing where it is. they also have devices available for cars like that, that dont have vss wires.
Jon
Installer/Help Technician
---coral springs florida---
Posted By: v_t8
Date Posted: August 01, 2006 at 2:52 AM
go to any electrical seller buy a hi speed inductive proximity switch with a sourcing output find any rotating point after the gearbox and mount proximity switch this will give you positve pulse for each rotation if the nav system cant calibrate you will have to mount on axles
vt8
