’05 Altima VSS speed wire
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79000
Printed Date: April 19, 2026 at 10:27 PM
Topic: ’05 Altima VSS speed wire
Posted By: dpdurst
Subject: ’05 Altima VSS speed wire
Date Posted: June 11, 2006 at 5:34 PM
I have an '05 Altima and getting ready to install the Avic D1 into the car. I have the stock (non bose) unit but have cruise control. What color is the vss wire I have to tap into and where can I find this at?
David
Posted By: djfearny2
Date Posted: June 11, 2006 at 6:09 PM
NISSAN, ALTIMA, 2005, Speed Sense
On vehicles without the 5 speed automatic transmission, can also use blue / YELLOW behind the instrument cluster.
Speed Sense pink or black      radio harness (Midline or BOSE only)
Jon
Installer/Help Technician
---coral springs florida---
Posted By: dpdurst
Date Posted: June 11, 2006 at 9:15 PM
So I assume there is only 1 blue / YELLOW on the harness going the inst cluster then? Unless I find the pink or black in harness, but normally black is ground so what color would that be in the radio harness then?
Posted By: dpdurst
Date Posted: June 11, 2006 at 9:46 PM
I got it, the radio is grounded through the frame --
Posted By: darblueangel
Date Posted: July 07, 2006 at 7:36 PM
Did you find the speed wire. Where did you find it and what colour was the wire. I'm trying to find it myself to hook up my AVEC 3. Plus did you get the reverse wire hooked up. Where did you find it and what colour was it.
